How does the average MPG get worked out on the mfd display ?,
Is it per trip ,or over a peiod of time?
Can it be reset to zero to start again?
Average MPG
- Kev
- Administrator
Re: Average MPG
I'm pretty sure it's the average for that trip. You also have a little 1 and 2 in the top corner for current and 'lifetime' values. You can zero it by holding the OK button.
blz-8027
- In: Night Blue
Re: Average MPG
Thanks ill have a lookKev wrote:I'm pretty sure it's the average for that trip. You also have a little 1 and 2 in the top corner for current and 'lifetime' values. You can zero it by holding the OK button.
Re: Average MPG
Memory 1 - is the trip average MPG and resets after the ignition has been switched off circa 2 hours. All parameters displayed with a "1" on the top right corner are also reset.
Memory 2 - is the cumulative average mpg over time and resets after 99h 59m of driving time or if manually reset by pressing and holding the "ok" button for circa 2 secs. The total distance, total driving time are also reset. Basically, Amy of the parameters that are displayed with a "2" on the top right corner.
The instantaneous MPG can also be displayed on the MFD and when it's being displayed there is no "1" or "2" on the too right corner and no average sign in front of the value (0 to 200mpg)
blz-8027
- In: Night Blue
Re: Average MPG
i dont get a number 1 ,just the number2 ?
Found it ,its either 1 or 2 ,you need to press ok
- JeffW
Re: Average MPG
Press the OK button to swap between the 1 & 2blz-8027 wrote:i dont get a number 1 ,just the number2 ?
blz-8027
- In: Night Blue
Re: Average MPG
Beat me to itJeffW wrote:Press the OK button to swap between the 1 & 2blz-8027 wrote:i dont get a number 1 ,just the number2 ?
- JeffW
Re: Average MPG
[emoji106]
