RNS 510 lost coding
00beyoung
Options: RNS510
Remap
RNS 510 lost coding
Post by 00beyoung »
Morning All,
Not sure if anyone can help with VAGCOM and my RNS510 issue. Car is a 2009 58 Reg.
Sound stopped working on the unit following what I suspect to have been a drop in voltage. Went in to the stealers and they fcukd it up got a black screen and could not code, they say it is not the original unit (which may be the case). Following a diagnostics test using my Delphi I managed to do a speaker test on all speakers and they are working fine however still no sound.
I plugged into vagcom and went into 37-Navigation, 7-coding and adjusted all codes to what I deemed correct (no sound system installed was one of the options selected). See below code list:-
I also went into the can bus module and installation, navigation and radio were not selected so I selected these options and saved (I have done a reset ever time I have made an alteration also). I cleared the fault codes from the radio section and they have stayed cleared but still no sound from the stereo.
I am convinced this is something simple on VAGCOM like a code or an un-ticked box but I am no Wiz on this. See below autoscan information relevant to the stereo.
If anyone could tell me what I have missed it would be much appreciated.
Code: Select all
Tuesday,15,November,2016,19:39:25:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ13Z9V0#####   License Plate: WF58 ###
Mileage: 109440km-68002mi   Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 52 56
VIN: WVWZZZ13Z9V0#####  Mileage: 109440km/68002miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 1010
37-Navigation -- Status: Not registered 0001
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2,0L EDC 0000SG  3889
   Revision: 13H01---    Serial number: VWX7Z0H73N50I6
   Coding: 0001072
   Shop #: WSC 66565 257 00032
   VCID: 71E9334F685CC1966BD-8024
2 Faults Found:
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Lambda: 11.8 %
                    Lambda: 3.2 %
                    Voltage: 0.380 V
                    Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 763B40F5092300FE6E0C02ED902100823000
   Shop #: WSC 00020 790 00000
   VCID: 74E73A5BD74EF4BE80B-8021
1 Fault Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 54
                    Mileage: 107183 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 7
                    Count: 3
                    Count: 4096
                    Count: 128
                    Count: 29440
                    Count: 0
                    Count: 0
                    Count: 0
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6FED35377E68D7667D9-803A
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008403778
   Coding: EC880F0300041A0066960E001900000000087B075C400124000000000000
   VCID: 326BFC43ADDABA8E527-8067
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 180808 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     211008 054  0402
   Coding: 00209133
   Shop #: WSC 00020
6 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 90
                    Mileage: 107188 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 10.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01497 - Bulb for Blinkers; Front Right (M7)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 20
                    Reset counter: 91
                    Mileage: 107183 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: 108756 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 11.65 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 109319 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 7.60 V
                        OFF
                        ON
                        ON
                        ON
                        OFF
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 107183 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 9.60 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 1K0-919-475.clb
   Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
   Component: PARKHILFE     005 1506
   Revision: 00005000    Serial number: 0 263 004 300
   Coding: 100001
   VCID: 3561C75F9CB4ADB6775-8060
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 14100800450001
   Coding: 000180
   VCID: E6C3D0131192962E8EF-80B3
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D00CNT8
   Coding: 0012360
   Subsystem 1 - Serial number: 6332MSME3F7110525
   Subsystem 2 - Serial number: 6342MSME3F71254AJ
   Subsystem 3 - Serial number: 6352QSME050A520A9
   Subsystem 4 - Serial number: 6362QSME220C280AE
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 8305E987C2E04306091-80D6
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K8 920 960 E    HW: 1K8 920 960 E
   Component: KOMBIINSTRUMENT VDD 1244
   Revision: V0003000    Serial number: VWX7Z0H73N50I6
   Coding: 0003403
   Shop #: WSC 00113 210 60338
   VCID: 3365F94752C0B386591-8066
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 52
                    Mileage: 0 km
                    Time Indication: 0
[u][size=150][color=#FF0040]Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K089120678
   Coding: E9A81F06000212004001
   Shop #: WSC 00690 210 88437
   VCID: 377DCD5746B85FA6659-8062
4 Faults Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 13
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:34:09
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 14
                    Reset counter: 53
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:18:53
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 15
                    Reset counter: 53
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:18:56
03272 - Control Module for Audio Interface
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 53
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:18:56
[/color][/size][/u]
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1244
[color=#FF0000][size=150][u]Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667292471
   Coding: 010000
   VCID: 2541171F2C14DD36C75-8070
1 Fault Found:
01304 - Radio
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:21:15
[/u][/size][/color]
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H42 1400
   Revision: AB001001    Serial number: VWZ6Z7L9094198
   Coding: 0C000400040000A000
   Shop #: WSC 80093 222 69422
   VCID: 2D51EF3F74E4E5760F5-8078
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2022
   Coding: 0016949
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 174    2301
   Revision: 00H15000
   VCID: 2A5BE423850AF24EEA7-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0205
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81900A0002830C7F3F04840570085ACE903CA0
   Subsystem 1 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
   Subsystem 3 - Part No: 1K8 951 171
3 Faults Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 13
                    Mileage: 107183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:34:01
01135 - Interior Monitoring Sensors
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 72
                    Mileage: 107188 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:01:04
00323 - Vehicle Inclination Sensor (G384)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 108125 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:10:35
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 387FCE6B4BA650DE6C3-806D
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
End   ---------------------------------------------------------------------
00beyoung
Options: RNS510
Remap
Re: RNS 510 lost coding
Post by 00beyoung »
FYI I have looked high and low for a resolution but nothing has worked from various forums and rosstech.
Bump
spacewalker
In: Urano Grey
Post by spacewalker »
Clera errors 1st and then do Outpout Test for Speakers
For me - gateway (19) is too old to work with RNS 510
The earliest compatibile is Q ...you have S
No matter if radio is made by Delphi or Bosh / Blaupunkt
If was design for VW - will work , but must cooperate with other modules over CAN Gateway
Also every time you do CODING changes in RNS , make sure you do proper RESET , exit from VCDS will not apply changes
CCS via MFSW in 2005
https://www.youtube.com/watch?v=JQ8cBbe ... e=youtu.be" onclick="window.open(this.href);return false;
salsajoe
In: Salsa Red
Post by salsajoe »
If the radio was working then the correct code must have been input at some time (even if it not the original radio) and will not be lost even when the battery is removed unless as you say the stealers have managed to 'lose it' while messing with the coding. In which case it is their problem to sort out.
00beyoung
Options: RNS510
Remap
Post by 00beyoung »
Thanks both, I think battery got so low it lost coding.
I will try and plug it in next week when I'm not working. Will probably post another question then :-D
Ben
