Battery dying, I think
House
In: Indium Grey
Options: Panoramic Sunroof, Sat Nav, Bluetooth, Leather seats
Post by House »
Hi all,
Had my Scirocco for 3 weeks now and the battery has just started struggling when starting the car. Took it on 25 mile drive earlier, and when I got in it a couple of hours later, it still struggles. Starts quickly but you can hear the engine turn over slowly.
Can anyone point me out on the best things to check? If its a battery issue then it wont be covered by the warranty, and I'll just go out and buy a new one. However if its an alternator/starter motor issue, then it will be covered.
Thanks in advance
James
C00PS
Options: Red LED foot well lights.
Red LED reading lights.
LED number plate lights.
Yeti tail pipes.
Metal pedals.
GT engraved foot rest pedal.
GT steering wheel Emblem.
Re: Battery dying, I think
Post by C00PS »
Get your hands on a multi meter and measure the output of the battery. Not sure on voltage but I think it's 14v.
Sent from my SM-G925F using Tapatalk
House
In: Indium Grey
Post by House »
I am guessing if I change the battery over myself, will I loose the settings if I disconnect the battery?
With the engine running the voltage should be between 13.8 and 14.4V and without the engine running it should be around 12V.
Battery needs to be tested under load. Just pop into your local fast fit place and ask them to test it. If it's over 5 years old and you have any doubt just buy a new Bosch or Varta one. Much less hassle in the long run
House
In: Indium Grey
Post by House »
Great thanks, will go a get a multimeter to test. It is 5 years old, so could just need a new battery. Will I cause any problems disconnecting the car from the battery whilst I swap them over? Don't have the radio code so that could be annoying.
As long as the headunit hasn't been retro-fitted you don't need a code.
ESP light will stay on until you drive the car until the Steering Angle Sensor calibrates.
House
In: Indium Grey
Post by House »
Brill, thanks for the replies.
House
In: Indium Grey
Post by House »
Ok not convinced it's battery then. Engine off, 12.25 volts. Engine on about 14 volts. Starter motor? I'll go get the battery tested at a garage.
House
In: Indium Grey
Post by House »
Ok so took it to a garage round the corner who very kindly tested it for me. They reckon its knackered and not a problem with the charging.
So went to Euro car parts and bought a new Bosch battery, one that they recommended for the Scirocco. Only problem is it is smaller. length is 246mm, where as the original battery is about 275mm. Have they given me the wrong one?
C00PS
Yeti tail pipes.
Metal pedals.
Post by C00PS »
House wrote:Ok so took it to a garage round the corner who very kindly tested it for me. They reckon its knackered and not a problem with the charging.
My battery went not so long ago. I got this one http://www.eurocarparts.com/mobile/ecp/ ... 43a&000020" onclick="window.open(this.href);return false;
Fitted in perfectly and noticed the difference straight away when I started the car.
No issue with the radio as long as it's the one that came with the car. You'll just need to drive down your road for the steering to calibrate.
House
In: Indium Grey
Post by House »
C00PS wrote: My battery went not so long ago. I got this one http://www.eurocarparts.com/mobile/ecp/ ... 43a&000020" onclick="window.open(this.href);return false;
Thanks C00PS. Took battery back to Euro Car Parts before they shut and asked for one of them, unfortunately none in stock, but got the S4 007, which was the right size.
All fitted, and drove up the road to clear calibrate the steering. Thanks all :D
