RNS 510 help please &VAG COM
will1987
Options: Pan roof
Truffle leather
Heated cow
Post by will1987 »
Hi guys know you get probably loads of these but help would be appreciated!!
Picked up my rocco yesterday and love it but has a normal radio I think with a silly touch phone kit which I have read doesn't play music, was wondering....
Can I buy any RNS 510, will want to play music and make calls via Bluetooth like in my new caddy van so will presume I need to buy one with Bluetooth obviously!!
I'm quite confident of fitting it with all the help on here but all tips would be highly appreciated,
Also would I need to put in a mic etc or can I use the existing from that silly "touch phone kit"
Will be willing to pay any one for the vag com etc and even to fit if the price is right!
Also looking for some vag com mods if any one is interested... Live in bucks and London so any one local give us a shout
Thanks people !!!
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: RNS 510 help please &VAG COM
Post by dimexi »
Yes, you can buy any RNS510 - though I would recommend the C units and above (I think they go from A - P at the moment)
The RNS 510 does NOT have inbuilt bluetooth, so you will have to buy the VW OEM bluetooth kit, or a fiscon bluetooth kit to go with your RNS510
The bluetooth kit you buy should come with a microphone, providing you buy the right one.
No, you cannot use the microphone from your touch kit with an RNS 510
VAGCOM shouldn't be a problem where you are, there are a few who will be willing to help.
Hope this helps
lewihoga
I drive a: 1.4 TSI 122/125
In: Salsa Red
Options: Rear parking sensors, Yeti Exhaust tips, Octavia RS Pedals, Bluefin remap, Full LED interior, RNS 510 retrofit with OEM bluetooth, VCDS MODS
Post by lewihoga »
Part numbers I used:
VW Mic: 3B0 035 711B
Bluetooth Module: 5K0 035 730 E (Or anyone one just make sure its UHV so you can use all types of phones i.e. iphone, etc.)
Wiring harness: Check the link
http://www.ebay.co.uk/itm/VW-SEAT-GENUI ... 3f375844fc
Thats all you need. Plus obviously the rns 510. I got the LED version D works perfectly. Then you just need to do a bit of VAGCOM coding and you're all set.
PS put the bt module behind the climate control unit as opposed to under the seat! Saves so much hassle you don't have that crappy foam block under your seat!
