This may be a really stupid question, but all I can see in the MFD is stuff related to mileage, speed, trip etc. in the user manual it says that i can adjust other options like the reversing mirror or lights,and I cant find this anywhere, are there different versions?
You have a midline MFD. The extras are in the Highline. The manual covers both but is not well laid out.
There may be one or two other things you can show / adjust using the indicator stalk method - can't remember what it says in the manual. But as RW! says you only have access to some of the options described in the manual with the Mid-line MFD.
With the 1.4 you need to specify the multi-function steering wheel as an extra which includes the Hi-line MFD upgrade as well.
