I've had my car for about 16 months, an the air con has stopped working intermittently
has anyone else experienced the same problem? (I had a quick search and nothing jumped out)
Basically about 50% of occasions during the nice recent weather, i get in the car, set the temp to LO, the fan about midway, and i get lovely warm outside air coming, about 40% of the time it works fine, and the other 10% it starts to work, then stops after about 10 mins of driving. it doesn't matter what settings i have, whether i use the auto function, or have the air recirculating or not.
Of course, the VW are about as competent at identifying problems as my mum is at ski jumping. They had the car last week, after about an hour of dropping it off, I got a phone call to say there was no problem with it. I advised the helpful chap I was competent in the complicated art of using climate control, and I can assure him it doesn't about 50% of the time. I had laser eye surgery the day i dropped the car off and couldn't drive for a week anyway, so I asked if they'd try it again over a few days.
I went to collect the car on Monday, and low and behold i got in the car, started the engine, sat there for about 10 minutes & nothing worked. I left it running, flagged down a receptioninst, and got the servive fellow (not a mechanic, just the monkey that takes your money) to come and witness. He agreed it wasn't working, and I have now left the car with them again. So, they phoned me this morning, and said they were sat in the car & it's working fine, and they'll only fix it if they can identify the problem, which kinda makes sense, although I don't get the impression they're trying very hard to find it. They have given me a courtesy car (no scirocco mind you) and intend to keep the car a few days to try and replicate the fault.
So the questions I have are:
1). has anyone else had the same problem? if so did you find a sure fire method of replicating the fault? and do you know what vw did to fix it.
2). What do I do if they insist they cannot recreate the fault. I have proved to them myself that it doesn't work, & don't know what else I can do.
3). Should I just push for them to replace the whole climate control unit?
I am off to the south of france in the car next month, expensive ferry crossing already bookes, and am very nervous that i'm gonna be doing the drive without any aircon. 2 kids in the back are gonna be way too much hard work.
Thanks in advance for any help
Al
