Does anybodies coming home lights work? Mine appear not be working and gone into local dealer and they couldn't solve it either!
Coming home lights
etotheip
Coming home lights
Hey there,
Still going strong =)
robrob
Re: Coming home lights
Mine work fine.
Though I have to say I hardly ever use them as since they are not Automatic, I forget they exist...
- CTRnutter
When you take your keys out the ignition if its dark pull the light stalk towards you twice, that will actiavte the lights which will stay on for however long you set them for on the MDI,etotheip wrote:Hey there,
If that doesnt work I have no idea sorry
Car is now Sold!!!!! BMW 7 Series for now as nice and big but holding out for something a little special as my toy
- CTRnutter
Ok I'll be throwing the keys at the dealer tomorrow to fix the same problem as it appears mine has stopped working too as I went out to check to see if what I had told you was correctCTRnutter wrote:When you take your keys out the ignition if its dark pull the light stalk towards you twice, that will actiavte the lights which will stay on for however long you set them for on the MDI,etotheip wrote:Hey there,
- rehmondo
I've only tried this once but for me as far as I remember I turn off the ignition flashed the full beam once and then pulled out the key, opened the door and that worked for me.
PS just make sure the coming home lights are turned on in the MDI.
- rehmondo
I just tried it now and still works the same for me
etotheip
Thanks for that folks and tried suggestions and still no luck. Dealer said they will speak to VW for fix!
easybreeze
- rehmondo
PS make sure the lights aren't set to 0 or to the side lights, leave them in the Auto position.etotheip wrote:Thanks for that folks and tried suggestions and still no luck. Dealer said they will speak to VW for fix!
etotheip
Yes DRLs are on always! and the switch has never left the 'auto' position but thanks for the input
- rehmondo
Can I just added, once I take the key out and flash the light - they don't come on at this point, they come on when I open the drivers door and stay on for the time I've set even after I've locked the car.
etotheip
rehmondo,
mine do that but the computer states that they should stay on for 30s!
- jonosussex
Yep - i just got the same problem too! coming home and leaving home lights don't work - even though they are set on in the MFD!. I'll try the headlight flasher fix. Does that fix it permanently or do you have to do it every time?
cheers.
cheers.
1996-1999 Mazda 323 2.0 V6
1999-2002 Celica 190
2002-2005 Celica T-sport
2005-2008 Golf GTi
2008-2011 'Roc 2.0 TSi manual - Rising Blue
2011- ?? Roc 2.0 TSi DSG Indium Grey
2005-2008 Golf GTi
simmytt
i think you have to flash the lights every time for them to work, i could be wrong and hope i am wrong as i find this to be a pain in the backside and its not what i would call auto,the come home lights on my mk2 leon fr worked as they should turn off ignition take key out lights came on.
- CTRnutter
OK set the setting in the mfd, then with the keys in the ignition flash the full beam once, take the keys out the ignition when you open the drivers door the lights will come on and switch off after however long you have programmed them to stay on for, I have only had to do this once and now they come on automatically every-time I open the door after a journey.
not sure why they stopped but I reset everything and all is fine again
simmytt
i have to flash lights every time for them to work,but i will double check my settings.
- jonosussex
Thnaks!! Sounds like a plan - will try this morning and report. But why dod the bl**dy things stop working?
Can anyone give me advice on the convenience menu in the MFD? I really don't understand it and the manual is not helpful...
cheers
cheers
2005-2008 Golf GTi
2005-2008 Golf GTi
etotheip
Still not working but will reset settings in computer and see if that helps!
- jonosussex
Mine haven't been working lately; followed this thread, then when all else failed I read the manual. Try page 59... Something like ....The coming/leaving home function nonly works if ............ it is dark....
Of course - I am now getting home in the light .. I thinks it a big DOH! from me...
2005-2008 Golf GTi
2005-2008 Golf GTi
- jonosussex
Yep - its dark, the coming home lights work!!!
On my GTi they worked day or night - that is why I was confuseb by Roccy - the clever little thing!!!
2005-2008 Golf GTi
2005-2008 Golf GTi
