have you got folding mirrors and VCDS ?
- Shaun
Long shot i know, but If so can you tell me what the value is in this screen on both drivers and passengers door controller ?
Re: have you got folding mrrors and VCDS ?
Electric Folding Mirrors:
Driver's Door Controller 0021047
Pass. Door Controller 0021302
What are you looking for?
- Shaun
Re: have you got folding mirrors and VCDS ?
I want to see what values a car with those fitted from the factory has in the blue boxes, i have seen your guide but it confuses me, when i added door warning lights the value was 64 and i just added this onto the 20000 (and example) and made 20064.
So if i was to add a door mirror that folds with ambient lights to the passenger mirror above (code 20790) i thought i would do
2 + 4096 + 20790 = 24888
- Shaun
Hmm, confused the hell out of me
, so how come adding the 64 for door warning lights worked ?
My current codes are
drivers 0017013
pass 0017012
i have just added the 64 (included in the numbers above) for door warning lights, as standard i have turn signal lights and heated ?
drivers 0017013
pass 0017012
The codes that appear as + numbers you do just add up to get the correct code.
I've done it many times, choose the options you want add them up and enter the code.
An example from the ross-tech site
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active
+08 = Seatbelt Warning active (NAR only)
+10 = Seatbelt Warning Driver & Passenger active (NAR only)
+16 = Secondary Display (Radio/Navigation) active
- Shaun
^ thx, so In my case, 2 + 4096 + 20790 = 24888
20790 being original code, 4096 being folded and 2 being puddle lights
- Shaun
OK, I have been out and tested the new code ( 0021111 ) in my old mirrors to see if it excepts the new code, it accepted it , i guess this is a good sign ?, also i scanned the controller expecting a fault and it came up with the fault below which is also good news i guess ? (as i still have original mirrors installed)
1 Fault found
00131 - Outside Door Handle Illumination/mirror Light Driver Side
012 - Electrical Fault In Circuit
1 Fault found
