XDS
petk
XDS
Had my car for two weeks now, fantastic car. I have checked all my options, except XDS. Everything has been fine with the car, so I'm sure it has XDS as ordered. But how do I check it?
Best,
Peter
Best,
Peter
Re: XDS
The traction control should be smoother than in cars without.You can feel it helping instead of just cutting the power abruptly as soon as a wheel loses grip.
I'm not sure if it's still active when you turn off the traction control but testing would be easy, quite a sharp turn and step on the loud pedal
. If it keeps spinning up then no XDS while the TCS is off.
Caput Mortuum
Re: XDS
XDS is controlled by the ESP so it shouldn't work either if ESP is disabled. Mind, I'm not sure if ESP can even be disabled totally.
Re: XDS
Kick.
I'm about to order a 1.4 TSI 160HP 'rocco with DDC shocks and manual gearbox. Now I'm wondering if I should pick the XDS option. Its not that expensive. (250 Euro here in Netherlands) But is it any good? I read in tests that for instance the Scirocco R, who has this as standard, is still suffering from spinning inner wheels in sharp, fast driven corners. Same is for the Skoda Fabia RS with XDS (a completely different car, of course)
I also wonder if there would make much difference for the 1.4 TSI, because it has much less torque than the "R" version.
By the way, I dont understand the difference between Traction Control and XDS. Anyone does? They both limit slip of the front wheels, right?
Caput Mortuum
Re: XDS
ESP has a function called EDS as standard, which is electronic differential slip. XDS is a feature that further enhances it this feature that tries to better emulate a real mechanical slip differential. What it does is that it regulates the power put through the inner wheel in corners, whereas the standard system only is capable to completely cut the power or from the inner wheel using the ABS. Correct me if I'm wrong!?!?
I went and tried to change my order to incorporate XDS but couldn't add it anymore at that point. First I was gutted but have since learned more of it and now am pretty much at ease. I probably would still add XDS had I got the chance, as it doesn't cost that much. There are quite a few reviews that don't give it much praise though. It has been called intrusive for one but I wouldn't know.
Re: XDS
Yeah, I expect it only to be good when it would deliver more power to the outer wheel then only TC would have done.
I've driven the Alfa Giulietta a couple of time which has a similair device. Indeed it corners very good, but so did the XDS-less Scirocco 1.4 I drove the other day.
Re: XDS
would be nice to here some feedback on XDS, i know one member who has it and previous car had a quaiffe lsd, i've heard mixed reports from some saying its a bit hit and miss so doesn't give the driver confidence
1 6 D
Re: XDS
Can somebody with original VCDS ask how to activate XDS on forum from link?
Now I don't have VCDS and I can't find help without actual Autoscan.
http://www.vagcomforum.de/index.php?sho ... st&p=66149" onclick="window.open(this.href);return false;
- luisgguedes
Re: XDS
You can turn off ESP! In VCDS go to ABS module > Adaptations > Channel (one of these) 88, 89 or 90 > set value from 1 to 0 > test > save.erichuyn wrote:ESP cannot be switched off completely on most VAG cars, Porsche and Lamborghini being the exceptionsand maybe some Audi RS models.
This way ESP is COMPLETELY turned OFF.
To activate XDS is also simple!
Just go to the ABS module > Long Coding > Byte 17 > activate Bit 3
Just like this
Only works on cars prior to week 45/2009, i.e. with new A/C.
1.4 TSI 160cv Sport DSG7 White
Full led (exterior+interior)
Vag-com costumization
Eibach Pro-kit
Eibach Pro-kit
Re: XDS
You mean that ALL roccos (from 45week 2009 with new climate control, and on)
have XDS software pre installed, and you can just activate it via vcds?
Are you sure? As far as i'm concerned, from week 45, it was an option from the factory, with a cost approximately
of 240euros...
of 240euros...
- luisgguedes
Re: XDS
YEP!!! ALL roccos have it pre installed!
Beyond making the step i told above.
You also have to go to adaptations> channel 36 > and then set a value from 0 to 2. This adjusts the sensitivity.
In 0 rarely intervenes.
In 1 its weak.
In 2 it's strong. (I use this one)
(In 3 not working.)
With all those steps i told you, the care changes completely! It's much more responsive, turns much better, if you turn off traction control you feel it even more. Actually you have the feeling that the car has all-wheel drive.
It works even in golfs and in Skodas.
It's completely a must do on vag-com!
In 1 its weak.
(In 3 not working.)
Eibach Pro-kit
Eibach Pro-kit
armjcb
Re: XDS
Hi all, I'm a little confused on whether its worth activating XDS on my September 2010 model, after reading other posts I am getting mixed messages on if it is pre installed on my model or if it is only on the vag com software as a routine section, any answers????
awesum
Re: XDS
I checked the settings on my Golf 6 GTI and its set to 0luisgguedes wrote:YEP!!! ALL roccos have it pre installed!
In 1 its weak.
(In 3 not working.)
Re: XDS
I've just set it up on mine, simples!
Now I just need to give it a road test tomorrow.
Life's too short to go slow
Skoda Yeti 4x4 Elegance 2.0CR
Re: XDS
Interesting, the car certainly seems more planted on the twisty bits, it will be interesting to see what it's like in the wet.
Re: XDS
Had the XDS enabled for a couple of months now and overall results are positive, definitely worth it if you have the cable. Traction control doesn't activate as early on and seems to make the car 'pivot' more through tight bends. Can even provoke the back end out now rather than just washing wide!! Hopefully looking to take the Roc on a second track day so will see if it helps at all there!
