noticed when driving it, that the bottom of the midline is giving a kph instead of a mph?!?!?
anyone got any idea of how to fix this and turn it to mph? im on a non multi-function wheel, if that helps
(will try and upload some piccies later when the weather is a bit nicer)
Not sure you can - I believe it's like that because the speedo doesn't show kph, thus you need kph showing down there if you're driving on the continent. Only fix, I guess, might be through vagcom - but don't go on the continent if you do that!
Options: Gone but never forgotten; Sumatra, Cruise, Parking Sensors, Flat Tyre Indicator, boot liner, hatchbag, premium sills, SciroccoCentral stickers & hedgehog! Ordered 23rd June 09 Build week 41 Handover 17th Oct 09 Off to his new home July 2016 after nearly 7 years & 88800 miles.
you will notice that on your speedo there is no indication of kph only mph, the kph reading on the mfd is for safety reasons. If you take your car on holiday to the continent you will not know what speed you are going in kph so no you can't change it
I'll just confirm that on kph cars, the "display alternative speed" (or whatever the MFD option is) it's in mph, and as stated above there's no changing it.
Candy White 1.4 TSI 160 - DSG, ACC, 18" Interlagos (Euro Premium&Sport packs), Alu Door Sills, Current VCDS Mods Needle Sweep, Cornering Fog Lights, Alarm Chirp, Emergency Break Warning, Dension Gateway 5, sort of..
thanks all
makes sense i suppose, i have many things to learn, like how not to panic when pulling off because the world comes at me slightly faster than it did in a 10yr old 1.2 corsa
What I don't like, and this may just be my misunderstanding. But when you have the Nav on and it has the little Directions on the MFD, you can switch to view - for example how many miles left in the tank. My focus could do that, as it has (Where the digital KPH is) the switchable section, which allowed you to cycle through the various options...
Options: Leather Seats, Panoramic Sunroof, Bi-Xenons, Winter Pack, De-badged, Sills, Boot liner, Rubber mats. ( Dealer forgot to charge for leather seats, tried to make me pay a month after delivery. Didn't happen. : D )
stuaz wrote:What I don't like, and this may just be my misunderstanding. But when you have the Nav on and it has the little Directions on the MFD, you can switch to view - for example how many miles left in the tank. My focus could do that, as it has (Where the digital KPH is) the switchable section, which allowed you to cycle through the various options...
My RCD allows me to cycle through different options to display there. I had it on Average Consumption for a while but it was making me drive too slowly.
hmmm. I assume by cycle you mean you just used the rocker switch? I notice yours are both GT's with, I am guessing the Steering controls etc. Mines a non GT - so maybe that has something to do with it.
