I am still trying to get dealer to switch off the auto headlight setting that has the headlights on permanently- the handbook says you can switch it off in some countries but the proceedure mentioned doesn't seem to work. Don't get me wrong I like headlights but would like to be in control of them. The dealer says they can't switch them off as they are a safety issue.
Does anyone know how to turn them off. Selecting sidelights still leaves the rear lights, side lights and instrument panel lights on
Auto Headlights
Re: Auto Headlights
scimitar
the headlights being on are daytime running lights, as you can not turn it off via the indicator method outlined in the manual I'm guessing your car is post week 45 2009 (MY2010.5) so see the following links as this has been discussed numerous times before.
http://www.sciroccocentral.co.uk/forum/ ... 0.5#p47294" onclick="window.open(this.href);return false;
& yes the dealers won't turn them off as they don't want to be told off even though the applicalbe legislation has not come into affect yet & only applies to cars manufactuered after the date but ho hum, a dealer that will is rarer than rocking horse sh*t
scimitar
Re: Auto Headlights
Many thanks for reply . I will try again with indicator method as car was delivered April 09.
I think I have found an independent specialist who will if indicator method doesn't work
Re: Auto Headlights
make sure the light switch is in the 0 position when you attempt the indicator method
scimitar
Re: Auto Headlights
Maybe I had a senior moment- will try again with light switch at 0
Many thanks
Many thanks
scimitar
Re: Auto Headlights
Have tried again with switch on 0 still won't turn off
Re: Auto Headlights
Scimitar
my apologies the penny just dropped, you don't have xenons do you? you will need vagcom to turn the drl's off as your car is MY2009. (see roccopedia for instructions)
the indicator method only works 'straight out of the box' for MY2009 with xenons & My2010 pre week 45 (xenon & halogen)
scimitar
Re: Auto Headlights
Thanks at least I know it's not just me being thick, will keep trying independent VAG specialists- have given up with dealer
