Flap on R back box ?
- Shaun
I was just nosing around the car today and looked at the exhaust back box, I noticed a motor attached to it and a rod ( the left exhaust end tailpipe on the scirocco) , a rod runs into the exhaust end pipe ?, I'm assuming this is like the flap on the R32 ?, question what does it actually do ?, reduce noise at lower revs, or help with back pressure etc ?
Re: Flap on R back box ?
oh yeah never noticed that before!
I think it must the "tuned noise" system they originally mentioned.
also there's 2 pipes going into the RH exit, and just one into the LH side one with the motor flap attached.
- raffoul232
I have a question about the exhaust on the r. Why did they only use 2 tubes on one side and only 1 on the other
ALL MODS ON HOLD
- Shaun
perhaps 4 was to many and 2 wasn't enough ?raffoul232 wrote:I have a question about the exhaust on the r. Why did they only use 2 tubes on one side and only 1 on the other
- raffoul232
hahahahahha, im serious why for the exhaust system they used 3. Or is the one on the left as thick as both put together?
ALL MODS ON HOLD
Its not a motor, but a vacuum operated valve.
Had a wee play with it tonight, just a flap that shuts off the pipe at that side. Not entirely sure why its there, its open at idle.
i'd say the RH side exit is operational at all times...while the other side is open at certain times. Does that make a change in exhaust note? Dunno.
- Shaun
Sorry, I was serious lol, perhaps a back pressure thing?, or as you say the two pipes are quite thin, and the sinle one if quite wide, I guess to accomidate the flapraffoul232 wrote:hahahahahha, im serious why for the exhaust system they used 3. Or is the one on the left as thick as both put together?
Anakin
that Car looks familiar.raffoul232 wrote:I have a question about the exhaust on the r. Why did they only use 2 tubes on one side and only 1 on the other
Solar Orange TT RS
well if you will go posting pics of your undercarriage on the internet..Anakin wrote:that Car looks familiar.raffoul232 wrote:I have a question about the exhaust on the r. Why did they only use 2 tubes on one side and only 1 on the other
- raffoul232
ALL MODS ON HOLD
monkeyman
That gotta look stupid in the winter when your sitting a traffic and smoke is only coming out of 1 tail pipe.
Or is it something to do with not covering people walking down the path with exhaust fumes? Which in that case its rather cleaver.
