DRL retrofit
Emerald
DRL retrofit
so i have a problen i did a facelift retrofit on my 2012 scirocco r and now i have a problem where the headlight drl wont turn on but the bumper drl now glows witch on the facelift sre actually indicators....so anyone know if i can code the drl to work like indicators
1.4_tsi
- In: Flash Red
Re: DRL retrofit
You will have to modify the wiring. There is no way the light functions can be changed via software, unfortunately
Emerald
Re: DRL retrofit
you know how to do that or do you know if you can buy a module to do that
1.4_tsi
- In: Flash Red
Re: DRL retrofit
I doubt there is a module for that. Is it the "Comfort" facelift bumper as fitted to the base, GT and R-line? It's worth doing a search on the forum as I am sure quite a few have done it before
There is a tutorial thread on fitting the facelift R bumper, which looks to be more complex, here:
https://www.sciroccocentral.co.uk/forum ... p?p=202954
It's quite a long thread so you might find some info relevant to retrofitting the non-R facelift bumper there as well
Emerald
Re: DRL retrofit
yeah i read the thread when i decidet to do the retrofit but no info on how to turn the drl into indicators thats the problem and it also wasnt a problem withc conecting the the lights since the calbe are pretty much the same so i would suspect i would need to code the lights but i dont know where to find it
