Hello, i have a 2012 1.4 twin charged rocco, and in the middle of a ride the car beeped 3 times, speedometer, rpm meter and the water temp gauge went to zero, and chack engine, steering wheel, abs, and traction control light all went on the same time.
I stopped, turn the car off and after a few minutes turned it on again and the problem disappeared.
Yesterday i got in the car and when i turned the key half the way low oil pressure, brake pedal depress, and some weird light turned on, and the car started and the engine cut in 2 seconds later.
I cant connect to the ecu with the obd scanner because it cannot detect it, but when I connected to the ecu directly it worked fine.
Any suggestions?
Weird problem i have
Shahafhakmon
