Hello!
Recently my scirocco 1.4 (CAVD) has been acting up. It all first started when it was a bit of a rainy day, I pushed it to 5k rpm’s and my engine light went flashing. I noticed a power loss and lifted off instantly. After letting the car sit for a few days and going to a couple of mechanics that all had no time. The light cleared itself. It was “cillinder deactivation” and random misfires. I don’t remember de DTC CODES.
After these went away and about 2-3 weeks later driving without any issues I decided to go for a stage 1 tune at a local tuner. No dyno just getting a default file. It drove great with 200hp for about a week. Now since 2 days ago I noticed that especially when the engine is colder it jerks, stutters loses power and is to be honest undrivable. However there are no lights on, no codes or anything. Just audible misfires and the jerking. I have a video of this as well.
Is there anyone that could help me further, it’s a 2010 1.4 manual gearbox with 215000 KM. Had an engine rebuilt about 60k km ago. Spark plugs where changed 7000km ago along with oil filter and air filter. Apart from that the history is unknown
1.4 TSI stuttering and misfiring after tune
tre-punti
- In: Pure White
Re: 1.4 TSI stuttering and misfiring after tune
When you say 'no codes', is that just from the dash, or has it been hooked-up to a diagnostic computer since the problems started?
Apni
I have Carly, only faults it shows is:
Infotainment gateway - non original radio
Front Right Parking light defect , Front Left Parking Light Defect
P04BF - Control Curcuit for Fuel Flap (I had this issue for a while before it jerked)
tre-punti
- In: Pure White
You need to get it onto a VAG (or compatible) diagnostic computer IMHO. My first reaction is that this could be an ignition coil problem, but the diagnostics will confirm any misfire (and identify the cylinder affected).
Apni
I have a hex v2 with vcds (non genuine) I can attempt to see if this shows anything and will update you later today, would you recommend me to get new coils for all 4 cillinders when replacing?
tre-punti
- In: Pure White
I can only speak from my own experience, but when I had a Scirocco ignition coil fail, I had all of them replaced. I'd had a previous car (not a VW) where the coils failed one after the other over quite a short time, so I figured I'd get the pain out of the way in one go. If there's a misfire, it doesn't do the spark plug any favours either.
Apni
As an update, here is the VCDS Auto scan
Code: Select all
Wednesday,03,July,2024,13:21:55:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVWZZZ13Z9V020147 License Plate:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ13Z9V020147 Mileage: 215110km-133663miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 AT HW: 03C 906 027 F
Component: MED17.5.5 G 5859
Revision: L1H08--- Serial number: VWX7Z0HN3N60GY
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 73E56ACB12B5210E4E-8026
VINID: 9E69EAAAA043A899800800441C3AAFB3D6
No fault code found.
Readiness: 0010 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H31 0107
Revision: 00H31001
Coding: 743B60F5092400FA2E0C06E890200040300000
Shop #: WSC 59883 006 1048576
VCID: 78FF5DE7CBD342567B-802C
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 133 1213
Revision: 00133024 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 69D908A34079EBDEF4-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009133884
Coding: 218E8F0300041A0067960E001900000080097F075C40010C000000000000
Shop #: WSC 00020 790 00000
VCID: 3365AACB5235610E8E-8066
Subsystem 1 - Part No: 1K8 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 071008 022 0602
Coding: 00038805
Shop #: WSC 00020
2 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 215044 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 215044 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 12110800320002
Coding: 000180
VCID: 66C3039F9167C4A6D9-8032
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0G AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D00J7KX
Coding: 0012359
VCID: 6FED66BB7E9D05EEAA-803A
Subsystem 1 - Serial number: 6332MSME42131450Y
Subsystem 2 - Serial number: 6342MSME4213484CA
Subsystem 3 - Serial number: 6352QSME1E14372EN
Subsystem 4 - Serial number: 6362QSME31141E125
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 03053A0B4215118E5E-8056
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K8 920 860 D HW: 1K8 920 860 D
Component: KOMBIINSTRUMENT VDD 1244
Revision: V0003000 Serial number: VWX7Z0HN3N60GY
Coding: 0005103
Shop #: WSC 38985 001 1048576
VCID: 3169A0C3A829531EFC-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 34000000000000
Coding: E9881F06000202004000
VCID: 377D9EDB464D8D2EB2-8062
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 219
Mileage: 214611 km
Time Indication: 0
Date: 2000.00.00
Time: 10:35:37
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1244
Shop #: WSC 31594 001 1048576
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 F HW: 1Q0 959 701 F
Component: Tuer-SG 008 2035
Coding: 0016437
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 174 2301
Revision: 00H15000
VCID: 2A5BB7AF85FF20C63D-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 98900A0002834C7F3F048C0D60084A0BE03CA0
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 171
Reset counter: 197
Mileage: 214616 km
Time Indication: 0
Date: 2000.00.00
Time: 10:41:39
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1Q0 959 702 F HW: 1Q0 959 702 F
Coding: 0016436
VCID: 387F9DE74B538256BB-806C
Address 56: Radio Labels: None
Part No SW: 3TD 035 156 HW: 3TD 035 156
Component: RadioSK46MID 006 0010
Coding: 01000424041000
Shop #: WSC 00078 790 00000
VCID: 7F0DB6FBEEFD756E3A-802A
End-------------------------(Elapsed Time: 01:31)--------------------------
Apni
With some further inspection i can see in VCDS that engine readyness status is 0010 0000, the Oxygen Sensor(s) are Failed or Incomplete.
Anything related to misfire recoginition is disbaled and the counter for all the cilinders is 0
