Steering wheel lights, airbag error and horn issue
Fa4
Post by Fa4 »
Hi!
I don’t suppose anyone could help me figure out what’s going on. My steering wheel lights have gone out, the horn isn’t working, and I’ve had an airbag error ping up. Slight clicking nose when I turned the wheel when reversing then the above happened.
I don’t suppose it could be a fuse? And if so would anyone know which one?
2011 MK3 1.4 TSI Thank you in advance!!
fisherthewol
Options: Basic AF
Re: Steering wheel lights, airbag error and horn issue
Post by fisherthewol »
Here's the topic on fuses - unfortunately it seems that the attachments (diagrams etc) are deleted now. https://www.sciroccocentral.co.uk/forum ... hp?p=67103
I think I have the fusebox diagrams on my PC, I'll try and find it tomorrow.
Given what happened my guess would be something with your clock spring - either it is damaged and you need a new one, or something has shorted inside of it and blown a fuse - either way I'd start looking at getting a new one.
fisherthewol
Options: Basic AF
The Horn fuse is in fusebox "B", fuse F5/SB5; 15amp. Box B appears to be in the engine bay and is the one closer to the firewall.
Airbag's control unit is fuse 3 in box "C", which is the one inside the vehicle.
Again I would immediately guess the clock spring, but worth looking at the fuses anyway. Best of luck!
