DCC Fault Flashing (Already Replaced Sensors)
Bartek2508
Basically background story - purchased a PFL Scirocco R , ex show car which was on bags and the levelling sensors were both snapped therefore I replaced them and it’s been fine for 6 months or so however I still couldn’t get rid of the rear sensor fault , however 6-9 months go by and I got the fault codes attached below again , I went and replaced the rear sensor which is stated to be faulty causing my DCC button to flash and reset the codes and had no luck , both sensors are near enough new and I’m clutching at straws on what to do to fix the issue , can anyone shed some light on what they would attempt to rectify this issue or what it could be ? Possibly needing calibrated ? Coded ? Wiring fault ?
