Hi I am new to the forum,
I have a scirocco 1.4 tsi supercharged and turbo ,
I have owned the car one month and they said they changed the water pump which is the super charger clutch ,
Lost power after 3k revs so drove 5 mins to the local garage and they looked at my car and rev it like 8 times and seen the supercharger pulley wasn’t spinning but was working driving down , so I drove home ass it tuck me 4 mins and taken the intake pipe off and the turbo wheel has completely brown in side the turbo hosing , does any one no if this all could stop the super charger from engaging the magnetic clutch
Thanks James
Scirocco 1.4 tsi turbo and supercharger broken at same time?
Marshall200
Re: Scirocco 1.4 tsi turbo and supercharger broken at same t
First thing you need to do is scan the car for fault codes as this will probably point you in the right direction.
Marshall200
Is it just the clutch on the pulley that would stop the super charger from working. ? Or is there sensors or fuses that could stop it to ?
Marshall200
Just an update for anyone in the same please woth there car
I changed my turbo and put everything back together etc and then had all my codes cleared and it all works fine now , must because turbo blown it put super charger in limp mode or something …
