I've recently bought a 2009 2.0 tsi with heated leather seats. Today I noticed the passenger one wasnt warming up then also that the lumbar support controls didnt work.
I'm not sure if the lumbar was previously working but the heater definitely was and the only thing I can think of is that around a week ago I put the seat fully back while hoovering and perhaps this has disconnected the power somehow. Or possibly a foot may have caught and pulled something.
I've had another look under the seat for any obvious loose connections but it has the dynaudio amp under there and far more wiring than Id expected so am not sure which wires do what or what else to check.
I also checked fuses 34 and 37 in the drivers side fusebox although it seemed unlikely both of these would fail together and more likely something do with the power to the seat.
Just looking for suggestions on where to go from here to diagnose and fix?
Passenger seat electrics not working (lumbar/heat)
Re: Passenger seat electrics not working (lumbar/heat)
It will be one of the connections under the seat. It's a pretty common issue if you're not careful when sliding the seat back.
fuzzyfelt
Thanks Bob I will have another look. There seemed to be a few fastner/plug type cable tidy things alongone or two so that suggests to me theyve been pulled. Not sure exactly where theyre all supposed to go...do any diagrams or pictures exist of this stuff or is that just making it too easy?
Someone has posted a link where you can download the wiring diagrams but unfortunately this site is nightmare to find anything.fuzzyfelt wrote:Thanks Bob I will have another look. There seemed to be a few fastner/plug type cable tidy things alongone or two so that suggests to me theyve been pulled. Not sure exactly where theyre all supposed to go...do any diagrams or pictures exist of this stuff or is that just making it too easy?
From memory, there are connections to the seat for the following functions;
- lumbar
- heating
- airbag
- occupancy sensor
Edit: Roy_01 has the wiring diagrams.
viewtopic.php?f=2&t=25916&p=207853&hili ... am#p207853" onclick="window.open(this.href);return false;
If the link doesn't work then try messaging him as he's pretty active on this site.
fuzzyfelt
That is really helpful, cheers. Ill have another go when its not pissing down.
