If anyone could shed some light on this fault I have that would be amazing.
I'll start from the beginning...
In the petrol station the other day and as a got back into the car and shut the door the window did not move to its standard setting.... instead it stayed 2" from the top as if the door were open.
I tried to move the window switch up and down and no movement. The only thing was when I moved it down there was a clicking noise near the motor. ( It only clicked once when you pressed it)
I've tried to disconnect the battery to reset it, VW also replaced the motor itself and nothing.
Has anyone experienced anything like this?
Things to note:
1. Ive had a weak battery for a while now and have had to jump the car a couple of times. Could it be the weak battery??? I havent been able to change since covid.
2. I have sequential indicators installed on my car. Would this effect it? ( VW seem to think it is) I had them installed 3 months ago.
Any suggestions would be great...
Sent from my SM-G975F using Tapatalk
