Heard a bit of a rattle tonight on the way home coming from the back seats, and after having a look noticed that the plastic trim panel near the rear windows (the one which helps secure the roof lining and has Airbag written on it) was loose. Not quite sure how this would happen but I guess at some stage this has been removed by a previous owner.
Does anyone know what clip size holds this panel on as it seems to be missing (or has possibly fallen into the gap underneath)? Also, is there an actual airbag in that area behind the panel....not sure if it has gone off at some stage and that is why it is loose if there is.
Thanks in advance.
