Throttle pedal
blz-8027
In: Night Blue
Throttle pedal
Post by blz-8027 »
Recently fitted a new throttle peddle
how do i do the following statement ive read
Installation is the reverse of removal. If you are installing a new pedal you will need to adapt the pedal to the EMC using a Volkswagen scan tool or equivalent. If the car is an automatic or DSG, the kick down function will need to be re-established using the same tool.
Re: Throttle pedal
I would imagine using VCDS or a similar tool. If you have a look on the Ross Tech website, it should give you the detailed procedure to follow.
