My bluetooth has stopped working and when I try and select it on dash it goes straight past it, any thoughts?
Sent from my SM-G965F using Tapatalk
Bluetooth
Re: Bluetooth
try unplug and plug back in, could be a wiring broken in the loom
Hally123
- In: Oryx White
Re: Bluetooth
Thanks bit I got back in and like magic it worked, thanks anywayParadox1 wrote:try unplug and plug back in, could be a wiring broken in the loom
Vivalavangu
Re: Bluetooth
I think I’m having this same problem. What and how did you unplug the wires?
Re: Bluetooth
The Bluetooth module is located under the driver's seat (RHD) in a polystyrene box. Carefully unplug the connector(s) and plug back in.Vivalavangu wrote:I think I’m having this same problem. What and how did you unplug the wires?
I have it happen a couple of times but normally it comes back again after the ignition is cycled and have not needed to unplug the module.
