Hello, I am vinyl wrapping the car and have removed the passenger side without problem.
However, the driver side with the lock, I have removed the torx screw that seems to be holding the cylinder in place (picture 1) and I have also loosened the other torx screw as far as it will loosen (picture 2) but still the lock/cylinder won’t budge so I can’t remove it in order to remove the handle.
Please can someone help and tell me what I am doing wrong?
Thanks so much in advance!
How to remove driver door handle? 2008 Scirocco
Eheushsgsh
