Hi, I have the car listed in the title. I want to change my front and rear discs plus the pads to go with and I was wondering if anyone could tell me what the sizes are for the front and rear.
Thanks in advance!
Will
2.0 TSI GT 2008 Disc & Pad change
Willpill97
Re: 2.0 TSI GT 2008 Disc & Pad change
I believe the fronts are 312mm vented discs and the rears are 255mm solid discs.
The front brake pads are common between the 288mm and 312mm set ups.
Obviously, double check the information before ordering.
Willpill97
Thanks for the reply! Sorry to be a pain but what would the common pad be for the front 312mm disc?Cuprabob wrote:I believe the fronts are 312mm vented discs and the rears are 255mm solid discs.
By common pad, I mean they both share the same size of pad despite the different disc diameters.Willpill97 wrote:Thanks for the reply! Sorry to be a pain but what would the common pad be for the front 312mm disc?Cuprabob wrote:I believe the fronts are 312mm vented discs and the rears are 255mm solid discs.
Willpill97
Oh right okay, thanks for the help I appreciate it, didn't want to go from eurocarparts, did once and never doing that again haha.Cuprabob wrote:By common pad, I mean they both share the same size of pad despite the different disc diameters.Willpill97 wrote:Thanks for the reply! Sorry to be a pain but what would the common pad be for the front 312mm disc?Cuprabob wrote:I believe the fronts are 312mm vented discs and the rears are 255mm solid discs.
DJC013
Hello, have a look at the link below, found that the Pagid Brakebook is a good reference place for brakes
Link - https://www.brakebook.com/bb/pagid/en_G ... 4E?reset=1" onclick="window.open(this.href);return false;
