I want to buy a Scirocco
rolemachine
Options: I do not know yet
Post by rolemachine »
I want to buy a used Scirocco.
Manual.
I've seen one 2.0 cc but I do not know the consuption and I want an economic.
I read that has problems with their gearbox.
Any advice would be appreciated.
finetrond
Re: Hi
Post by finetrond »
First change the subject of you post so that members can get an idea of what your post is about.
Economy is controlled by right foot. Smaller engine with less HP will mostly use less. But that is boring.
DSG gearbox problems is something from 10 years ago. My R has 85000km on it . no issues, i drove it like a car should be. Lean on it hard, full throttle upshifts.
Collector of warning lights.
rolemachine
Re: I want to buy a Scirocco
Thanks for the answer finetrond.
The car I want to buy is from year 2010.I don't have the money for a newer version and also not such a privilege to waste money.
So what you think about the gearbox of a 2010 model.
In few days I will have a close look at it and maybe I will have more information
to share with you.
Thanks again
rolemachine
Here is a link on the car I want to buy https://www.merrjep.al/Njoftimi/Shitet/ ... in/5945416" onclick="window.open(this.href);return false;
Any opinions will be very helpful.Thanks
Zanic L3
Post by Zanic L3 »
2.0 TSI with 65-70k km's for €7k is really good. I bought mine 2.0 TSI DSG with 63k km's for €11k two years ago.
The deal looks really good, but check everything properly. Also keep in mind that you will need to change the chain and the chain tensioners (the chain tensioner is known to break, the job is around €1000-€1500). I'm in the process of getting it done now
rolemachine
Thanks for the reply Zanic and the heads up for the chain tensioners and chain replacing.
I am doing research about the car and I am so scared of what I am reading and it makes go further away :/
Zanic L3
Post by Zanic L3 »
rolemachine wrote:Thanks for the reply Zanic and the heads up for the chain tensioners and chain replacing.
Its just the chain issue and then the car will be good to go :)
Every car will have it problems unless you buy a Toyota or something
