I'm having random moments where the seat belt warning light and the tone comes up. It's caused by me, so the driver there is nothing on the passenger seats.
Does anyone know what this could be? It comes on at random moments and leaves again then.
How can I disable the annoying bing sound? (without vag-com or pulling cables?)
Seat belt warning at random moments?
Re: Seat belt warning at random moments?
Check the connections under the seat. It's been known for them to come loose if the seat is slid back full travel. If they are OK it's probably the microswitch in the seat belt receptor that the buckle engages with.
It should be possible to disable the warning with VCDS.
- Zanic L3
Cuprabob wrote:Check the connections under the seat. It's been known for them to come loose if the seat is slid back full travel. If they are OK it's probably the microswitch in the seat belt receptor that the buckle engages with.
Thanks for the swift answer Cuprabob.
How can I know if the connections are fine? If not, how expensive is the microswitch?
i'm going tomorrow to an indie for the oil change so i'll ask
I don't know if you can just change the microswitch. More than likely it will require a new seat belt buckle. If you wobble the buckle in the mechanism, can you get the warning to trigger?
With regards to the connections under the seat, you should be able to tell if if the connector has been dislodged.
Your indie should be able to check it for you.
