Where would you buy a 1.4 TSI map sensor ?
zakshaker
In: Sumatra
Post by zakshaker »
Hello,
not sure I'm in the right section to post this.
I need to change my map sensor for my scirocco 1.4 TSI (year 2010). where would you recomend to source one online ?
Re: Where would you buy a 1.4 TSI map sensor ?
Just type the part number into Ebay and some options should appear. Just make sure you buy an OEM one as cheap sensors can be false economy. If that fails call your local VAG dealer and maybe they will post one out to you if you can't get there in person.
zakshaker
In: Sumatra
Post by zakshaker »
Thanks cuprabob
I usually try to avoid eBay thought.
What is the original brand and reference for this part ?
Sorry, I don't know which brand but OEM sensors are normally Bosch.
With regards to the part number, you can get it off this website with a little patience.
http://www.oemepc.com" onclick="window.open(this.href);return false;
Otherwise just get it from your local dealer Other than the 2 year warranty on the part they will be aware if the sensor has been updated and will supply the latest part.
zakshaker
In: Sumatra
Post by zakshaker »
Thanks for your help :)
I've found the needed part here (but they do not deliver Mauritius Island) :
https://www.buycarparts.co.uk/bosch/1150756" onclick="window.open(this.href);return false;
For reference, the part number is : 038 906 051 C
zakshaker
In: Sumatra
Post by zakshaker »
So finally found one sensor locally. Brand is PIERBURG. There are quite some difference with original though
