Hi all,
Has anyone fitted the USB & Aux to a pre-facelift Scirocco? I recently fitted a MIB unit and I installed the USB port which fits in in front of the gear stick, beside the parking sensors button. However, this port does not work for Apple CarPlay so need the bigger one but have no idea where to fit it.
Any ideas?
Cheers!
USB Retrofit
davidscirocco
Re: USB Retrofit
Thanks but I only have an AUX port there so no where for it to slot in without cutting and as it’s quite a tight space, it would be a proper messy job doing that
Marius336
Re: USB Retrofit
you need
https://de.aliexpress.com/item/CarPlay- ... 0c44fb69-8" onclick="window.open(this.href);return false;
ore
1Q0 035 348 B Media in.
i have the 1Q0 media in, work with android auto and carplay
ore
Stoo
Re: USB Retrofit
Marius336 wrote:you need
Do you know if this will work for rcd330+?
Marius336
Re: USB Retrofit
no, rcd330 dont have yellow usb plug
