Hi is there anywhere I can check exactly what brakes are on my Rocco? Without taking the wheels off? And if I have to take the wheel off where should the caliper be branded? 63 plate TDi Bluemotion. 140bhp version. Rears are gone. Fronts aren't very good. Standard ones scared the crap out of me in Milton Keynes the other year and cooked off. So need to get something better. Are solid Pagid or Brembo worth it? Or do I need to go Mtec?? Thanks for any help.
Sent from my SM-G930F using Tapatalk
Brake help.
Re: Brake help.
Should be a sticker in the boot with the code on it, any code decipher on the net will let you know what you need.
TDiNumpty
Re: Brake help.
Thanks. Wish I knew. Took the wheels off to measure and check caliper manufacture. Just fitted some Pagid discs and pads on the rear today. Pretty easy considering I've never done it and a big saving on getting a garage to do it. Can't make my mind up on fronts now. ATE discs with ceramic pads or Mtec with yellow or green stuff pads. Don't like the brakes on the Rocco. Had complete fade last year scared the crap out of me
blz-8027
- In: Night Blue
Re: Brake help.
Did you ever get an answer to your question mate ?TDiNumpty wrote:Hi is there anywhere I can check exactly what brakes are on my Rocco? Without taking the wheels off? And if I have to take the wheel off where should the caliper be branded? 63 plate TDi Bluemotion. 140bhp version. Rears are gone. Fronts aren't very good. Standard ones scared the crap out of me in Milton Keynes the other year and cooked off. So need to get something better. Are solid Pagid or Brembo worth it? Or do I need to go Mtec?? Thanks for any help.
TDiNumpty
Re: Brake help.
Yes but too late. I took the wheels off checked the calipers. Pain in the butt. But then found out the info is on the car data sticker. There will be a corresponding code. 1ZE 1ZP 1KD etc. Check online and there should be a code to match your car.
blz-8027
- In: Night Blue
Re: Brake help.
Thanks for the reply n,the only code on my car sticker is for front brakes which is 1ze but cant match it with a sizeTDiNumpty wrote:Yes but too late. I took the wheels off checked the calipers. Pain in the butt. But then found out the info is on the car data sticker. There will be a corresponding code. 1ZE 1ZP 1KD etc. Check online and there should be a code to match your car.
TDiNumpty
Re: Brake help.
When you look online it will quote that code. They'll be that size.
TDiNumpty
Re: Brake help.
That's the same as mine. Should be an ATE caliper. 288mm
blz-8027
- In: Night Blue
Re: Brake help.
is the same code used for front and rearTDiNumpty wrote:That's the same as mine. Should be an ATE caliper. 288mm
thanks for the help
