Funny one this... Should have asked here when it first happened.
Not happened often though. Just a couple of times in the last eight years.
First time it happened I was at my son's house. A cold and rainy day. I locked the car, went into the house.
We thought we heard an alarm outside but ignored it. There is an alarm and I have set it off once accidentally and can't even remember what it sounds like. So, when you hear a car alarm going off you generally have an idea if it is yours. So, this is why we ignored it.
Went outside a couple of hours later and both the driver and passenger door windows were fully wound down. Wet seats... Freezing car, and all that stuff.
Didn't do it again for ages. Then a couple of months ago a work colleague asked "did you know your car windows are down?"
Both windows down again... Car doors still locked.
Anyone else experienced this behaviour?
cheers
andy
side windows lower when car locked...
- risingson
Re: side windows lower when car locked...
Yes mine have done this a few times - I have no idea why though!
Sent from my SM-G928F using Tapatalk
Andy b
- In: Night Blue
I don’t know if you know this, but if you push and hold the lock button on the remote keyfob then the windows drop
Mine used to do what yours did, the I found out that you can operate the windows from the keyfob
I guessed that the button was being pressed in my pocket by all the other crap in there, I put the car keys in another pocket and it hasn’t happen again
Could be the same with yours?
With the auto closure function the windows and sunroof (if fitted) close if you press and hold the lock button and open if you press and hold the unlock button. If you have a Highline display the function can be disabled in the convenience settings.Andy b wrote:I don’t know if you know this, but if you push and hold the lock button on the remote keyfob then the windows drop
Early Sciroccos and Golfs of the same era have been known to lower the windows by themselves and I believe the culprit is the door controllers.
andy_m
Thanks, no, I wasn't aware of that. I'll test that out later.Andy b wrote:I don’t know if you know this, but if you push and hold the lock button on the remote keyfob then the windows drop
andy_m
Again, thanks for the info... Really had me worried! As I said above, I'll test that outCuprabob wrote:With the auto closure function the windows and sunroof (if fitted) close if you press and hold the lock button and open if you press and hold the unlock button. If you have a Highline display the function can be disabled in the convenience settings.Andy b wrote:I don’t know if you know this, but if you push and hold the lock button on the remote keyfob then the windows drop
cheers
andy
