Airbag Error Alert on Dash
cjmcork
- In: Pure White
Hi folks, I had an Airbag Error alert come up on my dash last week - got the garage to re-set it, but it's come up again......looking for ideas on the why.......
Re: Airbag Error Alert on Dash
Check the connections under the seats. Otherwise you need to read the error code to find out which airbag is causing the issue and take it from there.
SciroccoEire
This! I had the same problem and ended up being a connection issueCuprabob wrote:Check the connections under the seats. Otherwise you need to read the error code to find out which airbag is causing the issue and take it from there.
