Dashcam wiring into the fuse box?
Zanic L3
Post by Zanic L3 »
I came across this thread on the mk7 golf forums. Has someone tried it did it work (with the tools listed above)? Is it identical to the Scirocco?
http://www.golfmk7.com/forums/showthread.php?t=10375" onclick="window.open(this.href);return false;
The camera I'm looking to get is Xiaomi Yi Dashcam.
xjay1337
Re: Dashcam wiring into the fuse box?
Post by xjay1337 »
Top row of the in-car fuse box.
click for build thread
Roy_01
In: Sumatra
Post by Roy_01 »
Better is to just put in a new fuse and wiring.
https://www.my-gti.com/601/addition-of- ... t-fuse-box" onclick="window.open(this.href);return false;
I would not recommend guiding the wiring through the door seal.
TimsRocco
Options: Sunroof
Reverse park sensors
18inch wheels
Post by TimsRocco »
I guides my wiring across the roof lining and down the door seal without issue. Then tapped into the wiring in the drivers door fuse box. Easy and looks very neat. Nothing visible.
