Hello
I have a problem that I can not solve with my left front window.
Suddenly there appeared a clattering noise when the window was raised in the stop.
And since then it is still there. I would have liked to know if any of you would be dealing with this problem without changing the engine. Here is a video to illustrate the problem
http://www.hostingpics.net/viewer.php?id=45951099f.jpg" onclick="window.open(this.href);return false;
Thanks.
Windows problem
Windows problem
Re: Windows problem
Nobody can help me in UK ?
wan sheikh nikmam
Re: Windows problem
Hello there, your window still can be close and open like normal? Or its stuck?wow45 wrote:Hello
And since then it is still there. I would have liked to know if any of you would be dealing with this problem without changing the engine. Here is a video to illustrate the problem. Sorry for my English I come from the South of France and I could not find a solution on the French forum. Thank you in advance.
Video
The noise comes towards the red rectangle.
Thanks.
Sent from my SM-T285 using Tapatalk
Re: Windows problem
Hy Wan,
she goes up and down normally.
I also re-sync the door open / close, but that did not change my problem, the noise is still there.
wan sheikh nikmam
Re: Windows problem
Logically, its related with the window regulator,maybe broken glass holder?wow45 wrote:Hy Wan,
I also re-sync the door open / close, but that did not change my problem, the noise is still there.![]()
wan sheikh nikmam
Re: Windows problem
Or maybe its the control module, did you change your window control module with different type module?
Re: Windows problem
wan sheikh nikmam wrote:Logically, its related with the window regulator,maybe broken glass holder?wow45 wrote:Hy Wan,
what you mean about "broken glass holder" ?
I have not changed anything, and nothing is broken visibly.
A friend, advised me, to change this piece. I'll take care of it as soon as possible.
Re: Windows problem
the switch did not change anything, the problem is still there
