Interior lights
Jarvis
Interior lights
Post by Jarvis »
Hi all. I have a problem with interior lights. I know that there is no fuse in my Scirocco MK3 2008. I tried to connect VCDS and delete error but it appeared right back. Tried to disconnect battery for half an hour also no good. Any things you can offer?
SciroccoCW
I drive a: 1.4 TSI 122/125
In: Oryx White
Options: 2015MY, Bi-Xenon, 18" Interlagos, Start/Stop, Bluetooth, Sat Nav, Panoramic Roof, Parking Sensors, Heated Seats, Interior LED's, Projector Puddle Lights, Mudflaps, Winter Pack, Rubber Mats, Stainless Steel Pedals, VCDS Tweaks
Re: Interior lights
Post by SciroccoCW »
Whats the problem your having? What is the error coming up as in VCDS?
Jarvis
Re: Interior lights
Post by Jarvis »
All interior lights is not working at all. All bulbs are standard and all good.
SciroccoCW
In: Oryx White
Re: Interior lights
Jarvis wrote:All interior lights is not working at all. All bulbs are standard and all good.
Can you post the VCDS error?
Re: Interior lights
Sounds as though you have a "short" somewhere in the circuit that is causing the protection circuit to shut down the module.
Did it just happen of it's own accord or were you changing / replacing bulbs when the fault occurred.
Jarvis
Re: Interior lights
Post by Jarvis »
Cuprabob wrote:Sounds as though you have a "short" somewhere in the circuit that is causing the protection circuit to shut down the module.
I was putting led's and all lights gone.
SciroccoCW
In: Oryx White
Re: Interior lights
You've probably got a bulb or LED shorting the circuit. Check each light individually, take each one out one by one and each time you remove a bulb test to see if the rest start working, until you narrow it down to the bulb/led causing the issue.
Re: Interior lights
Personally I would do it the other way and remove them all, reset the module and put each bulb back in one by one starting with the footwell lights as they tend to be the most problematic. I would also get them all working with normal bulbs before trying LEDs again. If you still want LEDs then replace each bulb in turn making sure it works before moving onto the next one.
The module measures the current drawn and if it's too low it prompts an error message, too high and it shuts the circuit down for safety.
If it now doesn't work with normal bulbs after being reset there is the risk the module has been damaged.
Jarvis
Re: Interior lights
Post by Jarvis »
I tried that. Did not helped. What module is controlling these bulbs?
