Dash Problems
Nerker
Dash Problems
Post by Nerker »
Hi Guys had the car in for a service today and also booked in for a couple of repairs before the warrantee runs out in a few weeks. We had noted that the corners of the climate temperature readout display had started to "craze" on the corners back in February and we mentioned it to our local dealer, who like us assumed that there was a failure in the manufacturing process. We decided to hang fire and wait until a service was due and get them done together, we booked them both in together for today, so we were a bit peed off when today the dealer advised that the repair was not a failure but damage !!!
has anyone else had or seen something similar to the problems / faults in the attached photo, any help would be appreciated
Nerker
Roy_01
In: Sumatra
Re: Dash Problems
Post by Roy_01 »
No thats not normal wear. Have you cleaned it with some agressive stuff?
If not then it must be a fabrication fault.
