Hello all
Done a search but cannot find the answer
can i fit a reverse camera to the RNS-310, with optical parking sensors
If so what has been fitted and what connectors do i need ,theres lots of aftermarket cameras around, but the stereo has different inputs on the rear to the typical phono plugs
Reverse camera
paddyz1
Re: Reverse camera
I wanted to do this but i have an rns510.
I could not because it does not have a video input on the back of the radio.
You will have to take the radio out and see if you have the input phono plug on the back. If you have it will have a yellow inner.
Do this before anything else.
blz-8027
- In: Night Blue
Re: Reverse camera
I have,it doesn'tpaddyz1 wrote:I wanted to do this but i have an rns510.
but apparently you can buy this camera with the multi-pin fitting
http://www.ebay.co.uk/itm/Rear-View-Rev ... 0005.m1851" onclick="window.open(this.href);return false;
