Sunroof Motor
Stazman
Options: Everything
Sunroof Motor
Post by Stazman »
Hi guys, can anyone help me please?
My sunroof motor decided to pack up last week, VW garage quoted my £538 +vat to install a new one. I found on on ebay for £30 and fitted it and sorted the problem. I went to start my car this morning and the battery was drained and wouldn't start the car just make loads of relay clicking noises. I've got my battery on charge now but would like any advice what might have caused this?
Thanks in advance.
Carl
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
No idea's guys?
Re: Sunroof Motor
Pull the fuse for the sunroof and put an ammeter across the terminals and check there is no current being drawn by the motor when not in use.
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
I'll try that, thanks.
Does anyone know which one this is as I can't see it on the diagram i've just downloaded?
Roy_01
In: Sumatra
Re: Sunroof Motor
Post by Roy_01 »
Fuse 33 from MY10
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
Is that from the box inside near the drivers door? How can you tell which one is 33?
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
Any ideas guys?
I've looked through my manual and there's no fuse diagram.
Does anyone have a pdf or image of one?
Carl
Re: Sunroof Motor
Have you seen this thread?
http://www.sciroccocentral.co.uk/forum/ ... =25&t=7403" onclick="window.open(this.href);return false;
When you remove the cover from the fuses you should see a numbered fuse list on the rear of the cover.
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
I can see it's 33 but I don't a list on the reverse of the fuse cover, that's my problem I don't know which one to pull out. I looked at the post suggested thanks but again I can't see which is the right one to pull out.
Re: Sunroof Motor
Unless I'm missing something the thread has a diagram of the fuse box at the end of the dash with each fuse being numbered. Fuse 33 being 5th row from the top, 2nd fuse in from the left. Another way is to start counting the fuses from the top left hand row, and then each row left to right u.til you get to 33.
Roy_01
In: Sumatra
Re: Sunroof Motor
Post by Roy_01 »
The fuses are numbered in the fusebox.....
Stazman
Options: Everything
Re: Sunroof Motor
Post by Stazman »
Thanks for the help guys, I didn't see the diagram at the bottom, really appreciate your advice.
Now my next task is to address is when the sunroof is down it's just slightly not all the way down. I've found this info which I guess applies?
http://forums.vwvortex.com/showthread.p ... oof-switch" onclick="window.open(this.href);return false;
