So I went over the car with a clay bar yesterday.. only the second time I've done it. I think the previous owner never clay bared or decontaminated the paint because it has little orange specks which look like tiny rust dots. I found that some of them pulled out with the clay bar but others wouldn't budge. I tried applying a bit more pressure but they still wouldn't budge. Should I try Iron X again?
Id like for the paint work to be perfect so I'm not polishing and sealing over imperfections and small specks of contamination like this.. but being new to detailing I'm not aware of the best methods or what to expect.
Twice since buying the car I have foamed the car, cleaned it with a microfibre wash mit two bucket method, then used Iron X, then clay bar, then polish and wax/sealant.
Clay bar - orange specks
- SciroccoCW
- In: Oryx White
- P44RYT
- I drive a: R-Line
Re: Clay bar - orange specks
What clay bar & clay lube are you using? Ones from eBay, "3M" ones or cheapos are absolutely a waste of time. Make sure you're using a branded clay bar such as AutoFinesse if you aren't already,
then i'd try some tar remover such as AutoGlym's Tar Remover liquid, works absolute wonders and got all of the orange and black dots off my paint!
- SciroccoCW
- In: Oryx White
I'm using Bilt Hambers medium clay with soapy water in a spray bottle, perhaps your right and I should have another once over with the CarPro Iron X to help remove or minimise the contaminants before using the clay bar again.
Harry_VW
bilt hamber make the best clay bars imo. the medium should do the job just fine. With the regular one ive managed to remove overspray. They always leave the paint feeling like glass.SciroccoCW wrote:I'm using Bilt Hambers medium clay with soapy water in a spray bottle, perhaps your right and I should have another once over with the CarPro Iron X to help remove or minimise the contaminants before using the clay bar again.
- SciroccoCW
- In: Oryx White
It just wouldn't take some of the orange specks out.. I was moving from right to left in straight lines across the panels over the contaminants. I tried applying a bit more pressure but they wouldn't come out. So perhaps I should use Iron X again
