Mirror twitching.
Zanic L3
Mirror twitching.
Post by Zanic L3 »
Hello,
When I unlock my car the windows (driver and passenger) twitch up and down very slightly. Is it because of a going dead battery?
They twitch when the key is not in ignition and also when I'm stationary with the key in ignition after that it's gone.
They only twitch when the car is unlocked
Roy_01
In: Sumatra
Re: Mirror twitching.
Post by Roy_01 »
Windows or mirror what is it? Windows twitching is normal because of the construction of the doors.
Zanic L3
Post by Zanic L3 »
Roy_01 wrote:Windows or mirror what is it? Windows twitching is normal because of the construction of the doors.
Uh I meant windows
So it's normal that they twitch very strangely up and down like they are having a spastic attack?
thecrofter
Options: Tracker, Recaro Seats, Pano Roof, RNS510, Dynaudio, Cruise, Black Gloss Folding Mirrors
Post by thecrofter »
Windows drop slightly to below the rubber seal. If you don't open the door within a few seconds they go back up.
2.0 TSi 280 R DSG Rising Blue / April 15 - 11 March 20
2.0 TDi 170 DSG R-Line Indium Grey / June 12 - April 15
2.0 GT TDi 170 DSG Salsa Red / May 10 - June 12
Zanic L3
Post by Zanic L3 »
thecrofter wrote:Windows drop slightly to below the rubber seal. If you don't open the door within a few seconds they go back up.
Ah ok that's it then, thanks.
Zanic L3
Post by Zanic L3 »
What's the reason they do this though?
Roy_01
In: Sumatra
Post by Roy_01 »
Because the window will damage the seal when it doesn't drop.
Just take a look at your car from close distance.
If you look closely, you will see your car has frameless windows, which means before you open the door the window has to drop to disengage from the seal. Come winter time you'll find out what happens if the window doesn't drop. :)
Zanic L3
Post by Zanic L3 »
Roy_01 wrote:Because the window will damage the seal when it doesn't drop.
Damn didn't think about that...
