My Scirocco has just celebrated its 7th birthday (64K miles). The AC has started sounding noisy, particularly at low speeds. Its sounds like the compressor is working at full load with a whirring sound which rises and falls with the engine revs. The AC itself is working fine and is cooler than ever - perhaps even more than usual.
I took the car into my local garage down the road in Llandudno Junction where we take my partner's car and they looked at it for half an hour and couldn't identify the noise or find anything wrong. For this they charged me nothing!
This morning I received a flyer from VW advertising a 'summer health check' for £20 including AC service so I phoned my local VW garage where I bought the car and where it has been serviced for the last 7 years (not Llandudno) and was quoted £42 for them to look at it. Bearing in mind I spend nearly £700 there in the spring for a service, MOT and new brakes I thought they could have done a bit more for me. Anyway I'm leaving it for the time being.
I would be grateful for any similar experiences and ideas as to what the problem might be.
Air Con Noisy
Billc
- I drive a: R-Line
- In: Ultra Violet
Re: Air Con Noisy
My previous Roc was doing that noise - the up and down whirry sound at low speeds - and I was scared it was the compressor dying and megabucks for a new one. Without telling them about the noise issue I just asked VW for an aircon service. Noise gone, problem solved. If I'd said "the aircon's making a whiney noise" I bet they'd have come up with something a LOT more expensive than an aircon service !!!
Bill in Norfants
JUNKMAN
Re: Air Con Noisy
Had the same problem on my R recently turned out to be low on gas once recharged no problems
Jon1952
Re: Air Con Noisy
Thanks for that info BillBillc wrote:My previous Roc was doing that noise - the up and down whirry sound at low speeds - and I was scared it was the compressor dying and megabucks for a new one. Without telling them about the noise issue I just asked VW for an aircon service. Noise gone, problem solved. If I'd said "the aircon's making a whiney noise" I bet they'd have come up with something a LOT more expensive than an aircon service !!!
Jon1952
Re: Air Con Noisy
Thanks for the infoJUNKMAN wrote:Had the same problem on my R recently turned out to be low on gas once recharged no problems
Jon1952
Re: Air Con Noisy
Just to follow up this story. The buzzing noise from my AC did not get any better so today while the car was in Halfords having a puncture repaired I asked them to do their £49 Air con service. They reported 70% of the gas was gone so it was recharged and the noise has disappeared. Well done Halfords!!Jon1952 wrote:My Scirocco has just celebrated its 7th birthday (64K miles). The AC has started sounding noisy, particularly at low speeds. Its sounds like the compressor is working at full load with a whirring sound which rises and falls with the engine revs. The AC itself is working fine and is cooler than ever - perhaps even more than usual.
