Service due menu
DL04LRL
In: Indium Grey
Service due menu
Post by DL04LRL »
Hi so on my old car there was a way of finding out when my next service was due, tried to do a few searches and all I can find is stuff for golfs ...
Is there any button sequence I should be doing to bring up when the next service is due?
Thanks in advance
Re: Service due menu
On my car (MY12) it's on one of the pages of the MFD named "Vehicle Status"
On older cars, I believe it's the same as the Golf. You switch on the ignition, put your seat belt on to put light out and then press and hold the trip reset button until it comes up on the display.
Otherwise just look at your service record and see when it was last serviced and that will give you an indication on when it's due.
DL04LRL
In: Indium Grey
Post by DL04LRL »
Hi thanks for the fast reply . Do I have to start the car or just switch on to power up the dash?
I've looked at the service records just wanted to see if it matches up with the car
DL04LRL wrote:Hi thanks for the fast reply . Do I have to start the car or just switch on to power up the dash?
No you don't have to start the car, just switch the ignition on. It won't work if any warning lights are flashing hence why you need to.put your seat belt on.
DL04LRL
In: Indium Grey
Post by DL04LRL »
I will give it a try and see if it works.
