Crazy Light Problem
davebradsre
Crazy Light Problem
Post by davebradsre »
Hello all,
I have a 2L TFSI on a 62 plate that has the following problem: a random splattering of lights are not working.
Front right head light unit complete.
Front left fog light
Front left indicator
Rear right reverse
Rear left indicator
Rear left Fog
I have swapped the headlights over and the unit was okay, the bulbs are also alright on the non working lights.
The dash tells me to check loads of lights but not all, I am at a loss, any ideas guys?
Advice appreciated.
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Re: Crazy Light Problem
Post by davidscirocco »
Check your fuse i had the same problem
davebradsre
Which fuse? They all look okay, is it under the bonnet or the side of the dash?
davidscirocco
sport pack
RCD 510
Under the bonnet. Check very well the connections. Try taking them off and put them back again or replacing them. I had the same problem. In my case my fuse was a bit loose and it kind of melt the plastic and i replace the fuse witch btw it looked ok and now everything is fine
davebradsre
Spot on all working now, thank you :)
davidscirocco
sport pack
RCD 510
No prob ;)
