Strange problem with mirrors
Komar
I drive a: 1.4 TSI 122/125
Post by Komar »
Hy,
I have a strange problem with my driverside miror (LHD car), I was washing my car and accidentally pushed a little bit the mirror with my spunge and it moved(I moved the motor i think)...
And now when I am adjusting my left mirror form the inside my right miror moves also parallel hahahhaa. After that I switch control to right miror and he works fine (solo).
Why is that happining?
Re: Strange problem with mirrors
That is normal operation. There is a setting within the convenience menu within the MFD that you can select / de-select the link.
If you adjust the driver's mirror the passenger one will move in relation. It's so if different drivers drive the car they only have to adjust one mirror. The car stores the offset between the driver's and the passengers mirror.
If you adjust the passenger side, only the passenger side will move. This adjustment changes the offset values.
Nothing to worry about.
