Scirocco Error Code
Liamnu94
Scirocco Error Code
Post by Liamnu94 »
Hi everyone my 2010 Scirocco came up with the error code P2563 - Turbocharger Boost Control Position Sensor Circuit: Implausible Signal and I had the engine management light on solid and the glow plug light flashing, now the diesel particulate filter light has come on as well. The car drives fine no weird noises, good throttle response, and turbo is boosting when its suppose to.
I wondered if anyone had any ideas what it could be potential be, I'm thinking maybe DPF sensor or the actual particulate filter needs cleaning...
Roy_01
In: Sumatra
Re: Scirocco Error Code
Post by Roy_01 »
The boost pressure sensor is most likely faulty.
Then the dpf can not regenerate because it needs this sensor.
You have to let it checked very soon because you can get problems with the dpf and maybe impossible to regenerate.
Liamnu94
Post by Liamnu94 »
is this the sensor on top of the actuator?
Roy_01
In: Sumatra
Post by Roy_01 »
Yes thats the one, its the position sensor.
They can check it by applying vacuüm on it.
