Wing Mirror Indicator Bulb
2207
Anyone got any guides or videos on replaceing the bulb? I've installed my Detane DRL's and the wing mirror indictors look a little dull now? thanks
Re: Wing Mirror Indicator Bulb
The indicator in the mirror is a LED unit therefore it's not a simple bulb change.
chelspeed
You mean the puddle light under the mirror to light up the door when you get in? That's a normal W5W or whatever they're called. I've seen a how to, will have a search. Here you go http://www.sciroccocentral.co.uk/forum/ ... 39&t=16396" onclick="window.open(this.href);return false; about 2/3 of the way down the first post.
- Roy_01
Puddle light is not an indicator light.
2207
i do mean the wing mirror repeater bulb, can it not be done ?
As I said, you need to replace the LED unit. It does not have a replaceable bulb. The unit costs around £25 and there are plenty of guides on line on how to change it.2207 wrote:i do mean the wing mirror repeater bulb, can it not be done ?
Part numbers and some more info on this thread
http://www.sciroccocentral.co.uk/forum/ ... =2&t=17450" onclick="window.open(this.href);return false;
