Hi folks,
After my other halves car threw an EML I had it tested by a member a while back on a diagnostics machine. It looked like the o2 sensor was at fault, the car ran ok if a little lumpy. Since then work and life have got in the way of doing anything about it, I now have a little time to sort it but can't for the life of me find the right part.
The car is a 2009 2.0 TSI with the red led screen, if anyone could point me in the direction of the correct part I will be hugely grateful, even a second hand one to put on and check it is at fault.
Cheers,
Luke
O2 Sensor?
blower
Re: O2 Sensor?
Let me know your engine code and i'll look it up for you, you can find your engine code in your service book - it will probably be one of the following: CBFA, CCTA, CAWB, CCZB
