The Wife managed to scrape my front bumper ... It's also full of stone chips so I thought would get it painted ...
Now I'd like to clean behind bumper and fit new lights so I thought would take bumper off to supply to Bodyshop ...
They are fine with that, but how much of a job is it to remove?
Front bumper removal?
Mr OCD
- In: Shadow Blue
- mackie01
Re: Front bumper removal?
The front of the car is easy enough to remove, I've never had any mechanical experience or that and I managed it on my own. The only tool you'll need is a t25 torx screwdriver. And I used 2 car jacks to raise the front up and get at the screws underneath. You'll need to know how to take the fog surrounds out and then take the bulbs out the fogs and sidelights/indicator. I started with the screws underneath then put the car back down, turned the wheel to the side to undo the 3 in the wheel arch and the one holding it to the front wing, popped the hood and undone the 4 at the front of the engine bay. Then its just a couple of clips holding it on, but a bit of force will take it off
Mr OCD
- In: Shadow Blue
- wensleydale
Just to add to Mackie's description, the screw holding the bumper to the wing is behind the wheel arch liner, but there is enough play to pull the liner out of the way to gain access.
Mr OCD
- In: Shadow Blue
Worth getting the grill inserts painted whilst the bumper is off?
Hello. I found an illustrated bumper removal guide here: https://remont-bampera.com/en/vw-scirocco
Hope it helps someone.
