Shocks
Lumiya
In: Silver Leaf
Shocks
Post by Lumiya »
I bought some H+R lowering springs for my DSG 61 plate 2.0 tsi Rocco last year and just used them with the standard OEM shocks. I'm getting a issue with noise coming from the rear when i go over bumps or rough road surface. Its like something knocks just the once when proceeding over the initial bump. I think its the rear drop down bar you use to get the rear springs into position, as I've used lowering springs and still remained to used the original shocks i'm wondering whether there is some play in between the drop down bar and the rear shocks.
So i am now looking for some decent shortened shocks to compliment my H+R lowering spring. Would appreciate some feedback guys because i cant seem to find any that fit my car.
Paradox1
Re: Shocks
Post by Paradox1 »
Koni shocks always get good reviews. saying that I've never used them but worth a shot
ed21
Options: h&r lowering
Re: Shocks
Post by ed21 »
Hi i have a similar set up using H&R and also getting a knocking noise from the rear of the car at low speed . Iv had 3 different guys check it out and cant find a logical solution to fix it. If it persists im considering changing back to stock as im worried the long term problems.
Would anyone have any views on this or is lumiya correct in changing to shorter shocks.
Paradox1
Re: Shocks
Post by Paradox1 »
have you checked the rear top mounts on the shocks?
SciroccoEire
Options: Milltek Cat back , H&R Springs , Stage 1 Remap
Re: Shocks
Post by SciroccoEire »
@ed21 Do a search on here for the tailgate rattle. That could be the sound you are hearing :shrug:
I had a constant knocking noise at low speed and over bumps and thats what was causing the problem.
There is a how to guide on here how to fix.Simple Solution.
Best of luck!
