Hi Guys,
I found a good deal on some MK5 R32 discs, calipers shields and hoses for a 345mm setup replacing my 288mm disks which ill probably put on the back if I can.
Should everything be a simple swap no need for spacers or anything? I think the R32 brakes are also 6 pot whereas the standard ones on mine are 4?
Cheers.
Mk5 R32 345MM Brake Discs and calipers
Re: Mk5 R32 345MM Brake Discs and calipers
Both set ups are single piston not 4 or 6 pot, should be plug and play, ttrs setup a better oem+ upgrade
you front brakes are 312mmdaves2369 wrote:Hi Guys,
Cheers.
Mr OCD
- In: Shadow Blue
Not all Scirocco's have 312mm fronts.Paradox1 wrote:you front brakes are 312mmdaves2369 wrote:Hi Guys,
Cheers.
I think he was going by the OP's profile which says he has a 2.0 TSI which does have 312mm discs on the front.Mr OCD wrote:Not all Scirocco's have 312mm fronts.Paradox1 wrote:you front brakes are 312mmdaves2369 wrote:Hi Guys,
Cheers.
daves2369
Cheers, Got them through the post today
I presumed mine were the smaller fronts as I know the rears are the smallest of the lot at 256 as i did the pads but these seem huge in comparison!
Chris-mowatt
Any update on this? We’re the a straight fit etc? Looking to do the same upgrade but both front & back from an r32
